Full Version: ActiveX in Cx-Supervisor
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-Supervisor
MML
I wonder if anyone has experience with the use of ActiveX controls in the Cx-Supervisor and if you have any problems? I think at the controls such as combobox, checkbox.
MM
Automation
See if you served this document Omron.
MML
Thanks, but I have a problem, because the ActiveX control stops responding and I have to switch off and restart Cx-Supervisor runtime
MM
tashinz
yes, u tried to use check box, but it was crashing runtime whenever page with checkbox was open. also, click action don't work properly so I used Mouse down and Mouse up. In the end I erased check boxes and used simple objects from cx-supervisor.
Berti Baker
QUOTE(MML @ Feb 26 2009, 12:32 PM) [snapback]79336[/snapback]
MM
Hiya,
Have you got multiple controls and multiple pages? The latest versions name each control uniquely but older versions didn't and could confuse the Runtime... so make sure the whole project has different object names.
Regards,
Bertie
MML
Each ActiveX component in the project got its name. The problem arises when I open the same page with the ActiveX component, a second or third.
MM
Berti Baker
QUOTE(MML @ Mar 1 2009, 07:56 PM) [snapback]79449[/snapback]
MM
This sounds like what I was saying. If you want to PM me a small example I'll review it, and try it on my machine which might help validate it as a common problem
Bertie.
