I am in the process of setting up a small network of mostly CompactLogix processors and a couple of SLC’s and a couple of MicroLogix 1000’s. I will be doing a small amount of messaging between processors and eventually have a SCADA system. I want everything to go over Ethernet.
I am having a heck of a time getting the 1761-NET-ENI’s working properly. I was able to use the configuration utility and assign IP addresses using my serial cable. Once this was done there were no more fault lights and everything seems ok. I can find the 1761-NET-ENI using the Ether/IP driver but if I click on it, it goes unresponsive. If I use the Ethernet driver, it shows up with the dreaded red X.
I’ve tried going online with a SLC 5/03 using who’s active and the Ether/IP driver and again things go unresponsive when I click on the device.
Lastly, I am using an older version of RSLinx Lite, 2.43.01.23 (CPR 6) and my laptop is running Vista. I haven’t had any problems with any other drivers or versions of RSLogix except help menus while running Vista. Anyone have any ideas?
Thanks!
