Full Version: NS on ethernet
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-Designer
ParaffinPower
Hi all
If I have an NS on ethernet, and the cable is disconnected, the screen stays the same.
With serial, it would say "Connecting..."
Is there any way for the NS to detect the comms has failed?
Cheer, Pp
tashinz
well, back when ns system software was 6.2 i had the same problem. to indicate in some way that there is comm error on plc-ethernet-ns configuration, i did the following:
in plc: cio3200 increment by 1 every sec
in ns: create a project script, when a value changed (the value is $SW14 - ns seconds counter).
the script is:
$W3201=$W3201+1;
IF (($W3201 >= 10 AND $B1000 == 0) OR ($W3201 >= 15 AND $B1000 == 1))
$W3201 = 0;
$W3202 = READHOSTW($W3200,1,100,3200,1);
ENDIF;
IF ($W3202 != 0)
$B1000 = 1;
ELSE
$B1000 = 0;
ENDIF;
so, if $B1000 is 1 then i make visible some lamp that says COMM ERROR. that's it. it works on every 10 (if there is communication) or 15 (if there is no communication) seconds.
if i remember correctly, when you use the READHOSTW command (unlike READCMEM), if it fails (no comm) it triggers a system pop-up window with warning. should check that though.
ParaffinPower
Hi tashinz
Pp
james_applied
My screens drop out with a warning if comms fail. Try the latest firmware or firmware in NS designer folder.
