Full Version: Cannot Verify EXTER Project
Forums.MrPLC.com > PLCs and Supporting Devices > Other PLCs
Sergei Troizky
I am using Information Designer 1.50 build 308 connected to EXTER T70 via ethernet port.
I can Send and Receive the project, but the Verify button in the transfer window is never active.
Any ideas about the reason?
ndzied1
QUOTE(Sergei Troizky @ Jan 29 2009, 09:33 AM) [snapback]78199[/snapback]
I've never used the verify button and mine is greyed out as well.
Just for yucks I started a blank Cimerx project and the verify button was available.
If you want to test a project then you can go to the main menu under Project / Test.
If I recally from the days of yesteryear, when all you had was slow serial connections, that may have been used to verify if the project on the PC matched the project on the HMI.
Is there something you are looking to do that you cannot do now?
