QUOTE(bryan372002 @ Jan 27 2009, 10:02 PM) [snapback]78118[/snapback]
have 2 machines each controlled by contrologix with ethernet/ip also using Ntron enet switches 508tx
each machine is on seperate networks 191.1.17.??? on one and 192.168.124.??? on the other.
can these 2 networks be tied together using a switch ? and without having to change IP addresses of either machine?
for the purpose of being able to connect to either system from a single location
Thanks Guys
Yes, you can do it, but the answer is that it is very, very ugly. Set all the network masks to 0.0.0.0 (no mask). This effectively means that all possible IP addresses are local. You will NOT be able to communicate with the machines outside of the local LAN (not necessarily a bad thing) because any machine with a "wide open" mask can't talk to a gateway (router).
It doesn't have to be as destructive for the PC's. In Windows, you can set multiple IP addresses on a single NIC card. Set up the PC with a proper mask and gateway IP address for the primary IP address. Then set up a secondary IP address with a reasonable mask (such as 255.255.255.0). The PC will recognize both PLC's as being on the local LAN and will properly route everything else to the gateway.
The "correct" way to solve this problem is with "IP masquerading" or 1:1 NAT translation. To do this, you need a router or a firewall. The Hirschmann EAGLE mGuard (also sold under the name innomation) costs about $1300 and can easily do the translation to make one of your networks "appear" mapped onto the other network. You can also buy a cheaper Cisco 1811 to do the same thing but you have to use Cisco's CLI/IOS interface and you will lose having a DIN rail mount device with industrial power ratings and the ability to collect diagnostic information from the firewall through Ethernet/IP.
Nothing in N-Tron's line lets you do this. Their gear is relatively primitive and somewhat overpriced.
