QUOTE(Haresh Mali @ Dec 29 2008, 02:48 AM) [snapback]77197[/snapback]
hi, i m new to this form, plz help me.
i am finding problem in communication with GEFanuc 9030, CPU350. getting the error massage " PLC port can not opended."
i m using SNP connector of the power supply PWR331.
the connecting cable is USB to serial converter and after DB female to DB 15 male converter cable.
i m using the same cable on the other 90-30 system with same cpu and cable works OK.
help me on this.
Hi ,
I was having this problems with versamax CPU last year .
When i tried to connect CUP "PLC port can not opended." MSG was there.
I my restarted laptop as it is without any change in setup.
Else if you have Program BackUP file with you.
You can remove battery, Palce it again and try to Communicate (This willdefinately Work)
Thanks
Tushar
help me on this.
Hi ,
I my restarted laptop as it is without any change in setup. And it worked well.
Thanks
Tushar
