Full Version: SYSWIN TO CX CONVERSION
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-Programmer
MIKE31
HI
I have converted a plc file from syswin 3.4 to cx programmer everything is fine except the documentation which slightly different than syswin .Is there a method so that documentations will be identical after conversion from syswin to cx are. Highly appreciated mike31
Sleepy Wombat
What do you mean by the documentation is slightly different ?
PdL
Perhaps you mean that certain characters in symbol names are not translated:
/ becomes DIVIDE
? becomes QUESTION
- becomes MINUS
bluebyu
If the differences you found are as PDL says, copy your symbols into Excel, repace each of those items with _ (The underscore) As an example, Excel allows you to replace all the "Minus" with whatever you want with only a few key strokes. (Edit, Replace)
Hope this helps
