Full Version: Connect CX-Simulator to VB6 using hostlink command
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > Other Omron Software
Husanto
HI ALL,
Possible to simulation using CX-Simulator virtual comm to VB6 using hostlink command?? How??
thanks
Husanto
PMCR
I don't believe you can connect using a virtual port.
If you had 2 physical ports on your PC, you could connect 1 to the other with a null modem, using 1 for VB and 1 for the serial port of the PLC in CX Simulator. This does work.
BITS N BYTES
We have used the following for testing a virtual .net interface.
You may give it a try [should work] with VB.
http://com0com.sourceforge.net/
Berti Baker
Hi,
CX-Simulator emulates a FINS node so if you're using Compolet or CX-Server Lite to access PLCs from VB then you can set it up to access just by the node number.
rgds
Bertie.
