QUOTE(pelly09 @ Nov 26 2008, 05:26 PM) [snapback]76257[/snapback]
hi all
i have never worked with compactlogix before and was wondering if it possible to communicate with plc-5 over DH+
thanks
steve
Unfortunately it isn't possible... Compactlogix platform hasn't this option...
Only way is to use a ControlLogix Gateway: you need to get a small chassis, a power supply, a 1756-ENBT and a 1756-DHRIO; cpu isn't needed
So, assuming that you have an ethernet/IP option in your CompactLogix, connecting it to the-ENBT you may "see" all what is in DH+ thru the bridge....not so cheaper but possible !
Hope this helps...
fuzzy logic
