Let Me See if I can Help Some. You must think in terms of Data Addresses Somewhat
QUOTE(JAYNAILS @ Dec 4 2008, 06:19 AM) [snapback]76515[/snapback]
Chassis 1
RACK 0 DC Input 10-30V 32 In, DC Input 10-30V 32 In, DC Input 10-30V 32 In, DC Input 10-30V 32 In
Use a 1771ASB at Rack 0 Group 0 for a full rack 8 I/O groups. This will give you 8 Input Ints of 16 bits each that will correspond 1 to 1 with you 4 sets of 32 bits
RACK 1 DC Output 10-60V 18 Out, DC Output 10-60V 18 Out, DC Output 10-60V 18 Out, DC Output
10-60V 18 Out
RACK 2 DC Output 10-60V 18 Out, DC Output 10-60V 18 Out, DC Output 10-60V 18 Out, DC Output
10-60V 18 Out
Am a little confused by this one - Don't know of any PLC 5 18 output cards. Know of several 16 output cards with 18 terminals on the strip. I assumed you had a standard PLC 5 16 output card.
Use a 1771 ASB at Rack 1 Group 0 for full rack 8 I/O groups. This will give you 8 Input and 8 output Ints and will cover Racks 1 and 2
RACK 3 ANA IN 12 BIT, ANA IN 12 BIT, ANA IN 12 BIT, ANA OUT 12 BIT
Use a 1771 ASB at Rack 3 Group 0 for a half rack 4 I/O Groups.
Then on this rack you'll need to add a Remote I/O Module for each analog Card.
Group 0 Slot 0 will be your first ANA IN
Group 1 Slot 0 will be your second ANA IN
Group 2 Slot 0 will be your third ANA IN
Group 3 Slot 0 will be your fourth ANA IN
Chassis 2
1771-ASB
RACK 4 ANA OUT 12 BIT, ANA OUT 12 BIT, ANA OUT 12 BIT, ANA OUT 12 BIT,
RACK 5 DC OUTPUT 10-60V 18 OUT, ANA OUT 12 BIT, DC OUTPUT 10-60V 18 OUT
Is Chassis 2 an 8 or 16 card slot rack. It will make a difference in how you configure for it.
For an 8 Card Rack with no Empty Slots.
Use a 1771ASB at Rack 4 Group 0 for a full rack 8 I/O groups.
Group 0 Slot 0 will be your first ANA OUT
Group 1 Slot 0 will be your second ANA OUT
Group 2 Slot 0 will be your third ANA OUT
Group 3 Slot 0 will be your fourth ANA OUT
See Comment Above concerning 18 versus 16 pt modules.
The Outputs will be the last 4 16 bit ints of the data for this rack.
For an 16 Card Rack with 8 Empty Slots.
Use a 1771ASB at Rack 4 Group 0 for a half rack 4 I/O groups.
Use a 1771ASB at Rack 5 Group 0 for a half rack 4 I/O groups.
The Outputs will be the 16 bit ints of the data for this rack.
RACK 10
1794 ASB, 1794 IB16, 1794 IB16, 1794 IB16, 1794 OB16, 1794 IB16, 1794 IE8
Use a 1794ASB at Rack 10 Group 0 for a three quarters rack 6 I/O groups.
The IB16 will line up with the Input Data Tag as will the OB16
Group 5 Slot 0 will be your 1794-IE8
RACK 11
1794 ASB, 1794 IB16, 1794 IB16, 1794 IB16, 1794 IB16, 1794 IB16, 1794 IB16, 1794 IB16
Use a 1794ASB at Rack 11 Group 0 for a full rack 8 I/O groups.
RACK 12
1794 ASB, 1794 IB16, 1794 IB16, 1794 IB16, 1794 OB16, 1794 IE8, 1794 OE4
Use a 1794ASB at Rack 12 Group 0 for a three quarters rack 6 I/O groups.
Group 4 Slot 0 will be your 1794-IE8
Group 5 Slot 0 will be your 1794-OE4
RACK 13
1794 ASB, 1794 IB16, 1794 IB16, 1794 IB16, 1794 IB16, 1794 IB16, 1794 OB16, 1794 IB16, 1794 IB16
Use a 1794ASB at Rack 13 Group 0 for a full rack 8 I/O groups.
RACK 14
1794 ASB, 1794 IB16, 1794 IB16, 1794 IB16, 1794 IB16, 1794 IB16, 1794 OB16, 1794 OB16
Use a 1794ASB at Rack 14 Group 0 for a full rack 8 I/O groups.
If this is not enough help post your attempt at laying out the tree and we'll try and guide you.
The attached Picture was my start at it until I hit the problem with racks 4 and 5.
[attachmentid=6999]
