Full Version: ML1100
HiGhVoLtAgEgUrU
Hey guys i'm using a serial port to goline and it wont let me establish a connection with ML 1100 Series A.
I'm using AB_DF1..it says the the target node is not a SLC500 or micorlogix controller
Mickey
QUOTE(HiGhVoLtAgEgUrU @ Nov 20 2008, 03:24 PM) [snapback]76001[/snapback]
Was the serial port connected to anything? Is it possible the port is configured for DH485 protocol or ASCII or something other then DF1? Do you have the offline file to check its port configuration?
What cable are you using? What version of RSLinx do you have?
HiGhVoLtAgEgUrU
QUOTE(HiGhVoLtAgEgUrU @ Nov 20 2008, 01:24 PM) [snapback]76001[/snapback]
i'm using rslink lite version.........and cable type is 2711-cbl-pm05 ser. C
now it says STA:00 Type:9C Term:34 Proc: 9c
TWControls
What version of RsLinx Lite are you using?
kaiser_will
Grab a paper clip and your meter and ohm out the pins of the cable just to make sure the cable is working fine. If you ever find a bad serial or DF1 cable, please cut it before tossing it in the trash. I have found, more than once, that someone fished a bad cable out of the trash.
If your cable is good, and your PC serial port settings are correct, then try using HyperTerminal to listen to the port comms.
If HyperTerm shows some periodic garbage, most likely the com port and cable are doing their thing. You can make a serial loopback plug/cable and download an application to test the serial port.
http://interface.centraltreasure.com/free_...t_software.html
Are you trying to AutoConfig the DF1 driver in RSLinx?
HiGhVoLtAgEgUrU
okey here is deal..It opened my other program fine. But evertime I open 1st program it doesnt want to do it. but I had other small code writeen for some other application, that one works fine. I'm able to download and run it fine. You guys think it's some in the config. i have done wrong?
TWControls
Make sure the driver listed under Comms > System Comms is the same on both programs.
Also, what version of RsLinx Lite are you running?
paulengr
Something I recently found out about ML 1100...you can flash the firmware up to Series B even if it's a Series A!
HiGhVoLtAgEgUrU
How do I flash it. I'm kinda new to PLC's. I"m sure you guys have explain this question to others about million times already. I"m very greatful for the help I get here. If it wasnt' for this site, I would have lost interest for PLCs.
TWControls
QUOTE(TWControls @ Nov 20 2008, 07:01 PM) [snapback]76021[/snapback]
Ok this is the last time I'm asking...
HiGhVoLtAgEgUrU
How do I know what version I'm using.. all it says Rslinx Lite??????/
is it this revision 2.42.00 (build 18)
QUOTE(TWControls @ Nov 21 2008, 07:05 AM) [snapback]76045[/snapback]
Sorry TW, I just didnt know how to find it. Now i posted it, is it right?
HiGhVoLtAgEgUrU
QUOTE(HiGhVoLtAgEgUrU @ Nov 21 2008, 06:08 AM) [snapback]76046[/snapback]
I got it guys, I suppose to use node 1, but somehow it was stuck in node 0 so i changed it and was able to get online.. thanks for the help.
Okey since I know how to hook it using DF1, How do I do it with ethernet. I have etherent switch. And I have I.P adress also. What I need to know is where do put all the stuff.
Bob O
Take a look at this thread and go through the links TW and others have posted.
http://forums.mrplc.com/index.php?showtopic=9514
HiGhVoLtAgEgUrU
thanks Bob.
