Full Version: Micrologix 1500
gertsc
Hello,
I have had the same program running for 10 month in a Micrologix 1500 with a couple of input and output modules and a HMI attacted.
Suddenly I get an errorcode 29h (An instruction attemted to perform an indirection outside the User Data file space). As soon I clear the error and setting the micrologix to run mode, the error appear right away.
I have tryed to look at the data and addresses related to my indirect address instructions, but I can't see anything wrong.
Any suggestions, how to figure out where in the program the error occour?
Thanks,
gert
b_carlton
All you can do is post your file here and let other eyes look. It may be a ;'forest for the trees' situation.
Mark-
Hello,
Not much data to go on.
#1 Put limit checks in before the address is referenced. I assume you have a finite range of addresses you wish to r/w using indirect addressing.
#2 Jump around parts of the code to try and isolate the offending rung(s).
#3 Find a way to log each address before it is referenced.
#4 I do not recall if possible on the ML but try single scan testing. If not set up a switch to jump to the offending code under your control.
Of course this all depends on being able to execute the program/make debugging changes without harm to the machinery or people.
Good luck,
Mark
http://www.peakhmi.com/
BobLfoot
Certain Flavors of Controllogix have shown what I consider a wierd problem when it comes to indirect addresing. A variable is used as the indirect reference in Subroutine A and needs to be between 0 an 15. In Subroutine A it is limit checked and never used if the value is greater than 15. However in Subroutine B it gets loaded with a 32 as a temporary register. The firs thing Sub A is reset it to zero. Guess what this faults the CLGX.
I agree that you check limits on all addresses.
b_carlton
The Micrologix (and others) during the prescan check for these incompatibilities, even if the actual logic would have prevented the call by bounds checking. For example, if you have a rung
If N7:10 < 20 then MOV 10 N20:[N7:10]
With the test because N20 only has 20 elements
But N7:10 = 21 then, on prescan, this error will be generated. You have to prevent even the possibility that a number which will be used as an indirect reference could be set out of the bounds of its intended target.
Mickey
QUOTE(gertsc @ Nov 18 2008, 01:02 PM) [snapback]75884[/snapback]
Hello,
Thanks,
gert
Is the HMI writing to the addresses in question?
gertsc
Thanks for all the replyes.
I started to eliminate program files untill the error dissapeared, and I found a where it happend. It seems to be a prescan check problem as mentioned in the sugestions. The error would not dissaper before I run all the program files without the pecific one, and then run that one at the end.
Initially I used the search/Find "[" to locate my indirect adresses, but it only indicated that I had 17 indirect addresses in one program file. That was not the case, I had two more in another program file, that the search/find function did not find, and that was where the problem was.
thanks for the help
gert
