QUOTE(Kevin777 @ Nov 14 2008, 10:00 AM) [snapback]75750[/snapback]
Hi, I have started a new job where we have a number of GE-PLCs. 90-70 programmed with Logic master, 90-30 programmed with Versapro, Vesamax, Koyo logic 30, Quick Panel programmed with unknown. From a little reading here, it seems that these software packages are limited to certain CPU's. I feel i will drown in the ocean of information.
Is there any site, or document that might help me to get up to speed on which series and cpu requires which software. Where to start? Please Help?
I recommend putting a list together with every piece of hardware that you will need to troubleshoot or program and then get with your GE Fanuc rep or software supplier. Right now you should be able to get the "right" Proficy Machine Edition software to cover all but the very old hardware (Koyo). The trick is to purchase just what you need, there are a lot of options and that you should look at, including the age (version) of each CPU.
