jokke
Nov 6 2008, 06:55 AM
Hello,
I have a problem witch making a network from 2 NT3S displays witch a CJ1M over a SCU41_V1 card. When the 2 displays are connected at the same time, only 1 of the displays receives a signal. With 1 display only at the network it works properly. Can somebody give me some advice wich parameters I have to Change?
Automation
Nov 7 2008, 05:52 PM
Do you communicate to 2 or 4 threads?
Do you connect the terminal FG like it indicates the manual? Disconnect it or connect it according to as you have it and it proves.
I have had bad experiences and not for the software configuration.
Hi,
Few questions?
Do both NT3 have different node numbers?
Are both NT3 talking to the same PLC?
NTlink or hostlink?
Is termination ON on the SCU?
If so add 2 pull up resistors to the network.
Send me both programs and I could have a look?
regards,
MPM
