escski
Sep 30 2008, 02:58 PM
I hope someone can help me out here....I have a system 5/03 of which is connected an analog card 1746-NI8 on one of the channels I am measuring resistance the range is 1- 10 ohms, however when I try to scale the input through the SCP instr... the counts are not stable at all ,,, I then measure the input voltage coming in from the resistance meter and its rock solid.... I thought I was picking up noise on the analog input but as I stated the voltage is solid..... I don't know where the noise would be coming from..... any ideas would be greatly appreciated.... note: the other channels are noisy as well...
TWControls
Sep 30 2008, 03:49 PM
Can you post a sketch of how you have your modules wired? These are 4-20mA
Mickey
Sep 30 2008, 03:58 PM
QUOTE(TWControls @ Sep 30 2008, 03:49 PM) [snapback]74097[/snapback]
Looks like there dip switch selectable voltage or current. (see pdf below)
But you are right, how he has it connected or what he has connected is confusing.
A drawing would help.
TWControls
Sep 30 2008, 04:06 PM
Mickey, what PDF creator do you use, for some reason I can only open up about half the PDFs you post. But you are correct, my mistake
escski
Sep 30 2008, 04:11 PM
all inputs are connected as differential, and are config as 0-10v, there is one channel that is not connected and is not Jumpered , I wonder if that would have any effect.
TWControls
Sep 30 2008, 04:32 PM
So where are you getting your power from? What do you have hooked to the + and -?
Provide a sketch if you can.
Also, if you put a voltmeter across the + and - of a particular channel, do you see this fluctuation? Is the reading what you expect?
Mickey
Sep 30 2008, 09:49 PM
QUOTE(TWControls @ Sep 30 2008, 04:06 PM) [snapback]74099[/snapback]
The one above was created by PDF995. But sometimes I use CutePDF writer. I have had complaints about CutePDF though.
finfin
Oct 1 2008, 07:42 AM
How much are the counts varying? all meters have dampening or filtering. Maybe you need to add filtering. You might try putting a scope on it if one is available. A capacitor in your circuit might help also.
click here.
