Full Version: Data Log Files
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-Designer
Mendon Systems
Has anyone been able to get an NS terminal to save more than 1 data log file. All the documentation says it will save up to 999 log files, but all I can get it to do is overwrite the existing file.
BITS N BYTES
I have not yet used the Data Log function on the NS.
However in the manual there is a note regarding files that may help you.
Mendon Systems
QUOTE(BITS N BYTES @ Sep 30 2008, 10:36 AM) [snapback]74083[/snapback]
Yes, I have that information. We are beginning to suspect this is a problem with the simulator in CX Designer and not with the actual NS terminal.
PdL
QUOTE(Mendon Systems @ Sep 30 2008, 06:33 PM) [snapback]74086[/snapback]
Sounds very plausible. I cannot confirm but give it a good chance to work with an actual NS Terminal.
There should be some list of functionality supported/not supported with NS/PT integrated simulation perhaps it says something on the limitations. It should be either in the NS manuals or CX-Simulator.
