Captinjon
Sep 22 2008, 10:38 AM
I've not really used Fanuc PLC's befor but i have a problem which im trying to solve.
Im using a 90-30 plc with a HE693PBM101 profibus master card. Attached to the profibus card is a Allen Bradley Powerflex 700s Drive. Im using proficy ME software.
The problem i have is that the feedback from the drive (Motor Speed) is a 32bit real value. The starting point for this address is %I793. If i try to use this as a input into any instruction (Move_Real, Mul_Real, ETC) i get an error because these intructions dont alow %Ixxx as a input. Even the conversion instructions dont allow it.
How am i supposed to get the value into a register in the PLC. I may just be really stupid but any help is greatly appriciated!
RussB
Sep 22 2008, 12:17 PM
QUOTE(Captinjon @ Sep 22 2008, 11:38 AM) [snapback]73853[/snapback]
Begin with a Move_Word, Length 2 from %I793 to an unused %Rx2. Now use the %R for your scaling or whatever.
Captinjon
Sep 22 2008, 01:32 PM
Thanks Russ,
How do i specify the length, ive not done much GE stuff befor!!!
RussB
Sep 23 2008, 09:55 PM
QUOTE(Captinjon @ Sep 22 2008, 02:32 PM) [snapback]73860[/snapback]
Thanks Russ,
Select the Function block and press the "2" key.
Captinjon
Oct 29 2008, 05:39 AM
Ive conected the drive to the PLC all the lights are green which indicated that its communicating on the network, however when i look in the input/output areas which the drive is mapped to i dont see anything.
Ive used Siemens before where you use function blocks to read and write data to/from the slave, is there anything like this for fanuc?
Does anyone have any other ideas what im doing wrong!?
Joern
Oct 29 2008, 05:58 AM
No, there are no function blocks needed in the 90-30. The old HE693PBM101 supports Profibus spec. version 1. May be, your drive needs more functions from version 2. Could you send me the gsd file of the AB drive and the PLC project?
Captinjon
Oct 29 2008, 06:11 AM
[attachmentid=6873]Attached is the GSD File and a copy of the project.
Thanks
GSD file is here (Had to change extension)
Joern
Oct 30 2008, 05:06 AM
If you look at the gsd file, there are several options to selct:
; Definition of modules
Module = "Ctrl/Stat & Ref/Fdbk (2+2bytes)" 0xC1, 0x83, 0x83, 0x01;
1
EndModule;
Module = "Ctrl/Stat & Ref/Fdbk (2+4bytes)" 0xC1, 0x85, 0x85, 0x02;
2
EndModule;
Module = "DataLink A (2x2bytes)" 0xC1, 0x83, 0x83, 0x03;
3
EndModule;
Module = "DataLink A (2x4bytes)" 0xC1, 0x87, 0x87, 0x04;
4
EndModule;
Module = "DataLink B (2x2bytes)" 0xC1, 0x83, 0x83, 0x05;
5
EndModule;
Module = "DataLink B (2x4bytes)" 0xC1, 0x87, 0x87, 0x06;
6
EndModule;
Module = "DataLink C (2x2bytes)" 0xC1, 0x83, 0x83, 0x07;
7
EndModule;
Module = "DataLink C (2x4bytes)" 0xC1, 0x87, 0x87, 0x08;
8
EndModule;
Module = "DataLink D (2x2bytes)" 0xC1, 0x83, 0x83, 0x09;
9
EndModule;
Module = "DataLink D (2x4bytes)" 0xC1, 0x87, 0x87, 0x0a;
10
EndModule;
Module = "Parameter Access" 0xC1, 0x87, 0x87, 0x0b;
11
EndModule;
Which option do you want to use?
But independend of your choice, you configured 2 input areas. All the Data Links consist on 1 input area and 1 output area.
Consistency should be "Entire Length"
Why did you use 6 and 8 byte length? I've seen only 2/2 or 4/4
Captinjon
Oct 30 2008, 05:53 AM
The way i understand the GSD file is that module 2 is for the control/status and reference/feedback and module 4 is for datalink A. The 700s drive uses 32bit reference/feedback and datalinks which is why i chose module 2 and 4. Module 2 is (2 + 4 bytes) which is why i used 6 bytes in total. The first 2 bytes are for the drive control/status and the other 4 bytes are for the reference/feedback. Module 4 is for datalink A which is (2*4 bytes) so i used 8 bytes in total. I did select the Consistency to be "Entire Length" but i had the same result. Each of the modules is type Input/output.
Am i looking at this correctly?
Thanks
Joern
Nov 7 2008, 06:35 AM
In this status now, I recommend to contact your local GEF office in Towcester. Probably, you would need somebody onsite.
Joern
