Leadcommander
Sep 17 2008, 07:15 PM
I have established Produced/Consumed CIP Messages between these two PLCs
To B&R_Dints[124] and From B&R_Dints[125]
I require to set up another 100 Dint array to read from the B&R PLC for information data every 15 minutes
I am trying to get a explicit message working
I am using a CIP Data Table Read
and the responce I get is:
Class or Instance not supported
I can not get this to work
Has anyone else been able to get this working?
Equipment:
ControlLogix version16
ENBT/A Ethernet Module
B&R X20 CP1485
Cheers
Contr_Conn
Sep 18 2008, 04:56 PM
"Class or Instance not supported" message comes from B&R and it means that they don't understand class or instance that you put in your CIP message.
Do you have example from B&R?
if you do then post it here along with your program and someone will take a look.
Leadcommander
Sep 18 2008, 08:00 PM
I have established the Implicit Messaging between the PLCs
Currently we have working:
BR_to_INSTLGX[124], DINT
INSTLGX_to_BR[125], DINT
These are defined in a Generic Ethernet Module in the AB RSLogix5K IO Tree
And in the eipcfg Data Object in the B&R Automation Studio
I would like to execute an explicit message to get an additional array of 100 DINTS about every 15 minutes
I have tried executing a “CIP Data Table Read” message
The message generates an error stating “Class or Instance not supported”
Error Code 16#0005
So I believe I need to use a Generic CIP message with Custom settings
I don't know the Class or Instance values I should be using. I have requested information from the support People of B&R PLCs
My question is, what the correct way to set up an Explicit Message from an AB ControlLogix to third party device
Equipment used for test:
1756-L63 ControlLogix Version 16.20 slot 3
1756-ENBT/A Ethernet Bridge Version 4.3 slot 6 IP 192.168.1.196
B&R X20 CP1485
IF2 IP 192.186.1.195
Sysconf V2.94
The Eipcfg file in the B&R reads
"#OWNIP=192.168.1.195"
"#OWNINTERFACE=IF2"
"#STATION=INSTLOGIX"
"#STATIONIP=192.168.1.196"
"#STATIONSTATUS=udTestStationStatus"
"#CONNAME=TESTLOGIX"
"#CONDIR=BOTH"
"#CONRPI=100"
"#INPUTASSEMBLY=AssemIn1"
"logi:BR_to_INSTLGX, DINT, 125"
"#OUTPUTASSEMBLY=AssemOut1"
"logi:INSTLGX_to_BR, DINT, 124"
"#ASSEMBLY=expMES"
"logi:TOPPROF1, DINT"
Any help on this would be appreciated
TWControls
Sep 18 2008, 08:32 PM
So you are implicitly communicating with Assembly 1? Your trying to write data to assembly 2 now? How do you have the B&R configured in the Controllogix? It may give a clue of how to setup the additional ones
SWAG
Message Type: CIP Generic
Service Type: Get Attribute Single
Instance 9
Class 4
Attribute 3
Destination DINT[125]
Don't forget to set your path
Leadcommander
Sep 21 2008, 04:23 PM
The Implicit messaging is working after I built a generic ethernet module in the IO Tree
This gives me an array of Dints To and From the B&R
I have tested writing data into the AB PLC and in the B&R PLC and the data is transferred across to each PLC as expected
No code was written in the AB PLC to get this working, just having the module defined worked.
I have tried getting a Generic CIP Message to read the tag "TOPPROF1"
I have just tried using
Service=0x01 (GetAttribAll),
Class=0x01 (Identity)
Instance=0x01 for first instance
As Generic attributes
The message gets done but the values in the destination don’t match source and if I change the values in the source the values in the destination remain the same. I believe I am reading data from the IP port settings or something? changing the class I then get different data in the destination but again it is static data and doesn't corresponds to the data entered into the source.
Contr_Conn
Sep 21 2008, 08:07 PM
Class 1, Instance 1, Attribute 1 is "Get Device Identity" object.
Look at the data returned as "ASCII" and you will see device description
Did you try TWControls parameters?
Leadcommander
Sep 21 2008, 08:40 PM
Yes I tried TW parameters
The Messsage errored with:
Error 16#0005
TWControls
Sep 21 2008, 09:04 PM
IF Assembly 1 is 101 then looks like the Instance should be 103 to get to Assembly 2
QUOTE
Instance 9 103
Class 4
Attribute 3
Rereading, I'm a little confuse. Which way are you trying to read? B&R to Controllogix or Controllogix to B&R?
Leadcommander
Sep 21 2008, 11:17 PM
I have succsess
The CIP Generic message is now working
Message Type CIP Generic
Service Type Get Attribute Single
Class 4
Instance 103
Attribute 3
Destination Test_Array
I now have two Explicit Messages getting Dint[100] each, every second
And the Dint[124] and a Dint[125] communicatng through the defined Ethernet Module in IO tree at 100ms
On the second Expilict message the Instance is set as 104
Thanks for all the Tips
Cheers
TWControls
Sep 22 2008, 07:22 AM
I don't know how far you plan on taking this but be aware that there are limitation to how many messages you can execute at a time. I would suggest staggering them. Since you are executing two messages every second, make it execute message 1, half second later execute message 2, half second later message 1...
click here.
