Add ASC-02 ascii card to a C200H rack system (for a printer).
Some of the issues and info:
1. C200H cpu already has two expansion racks.
2. All racks are full (all cards needed).
3. With parts already on-hand, I mounted the 9-slot backplane with the RT201 directly under rack "0". Terminator switch = on. Dip switches 1~6 as follows: off, off, on, off, off, off. Switch 3 set to on because program is already using words on 05000~05915 range as working bits.
4. So... I'll use words 06000~06915 on remote rack. I relocated 4 OD212 output cards from rack "0", slots 6,7,8 and 9 to the remote rack slots 6,7,8 and 9. I will perform find and replace function in my off-line copy of program; old address words Q00600~Q00915 will become Q06600~Q06915. I'am using CPT 1.12...(LOL). Laptop connection is made through host link card LK201-V1 in rack "0" slot 2.
5. I installed the RM201 (rotary set to "0") in slot 9 of rack "0"
6. I will install the ascii card in rack "0" slot 8 after I confirm equipment operation up to this point.
7. RS485 cable connection between RM & RT is done. Power wiring to RT is done.
8. So...if your still reading this and haven't switched to another topic by now, I would greatly appreciate any comments and suggestions before I power-up to transfer the program changes. This is my first C200H expansion/ remote project.
Thanks in advance
RAMO813
