Full Version: 4-20mA to Relay Output
Forums.MrPLC.com > PLCs and Supporting Devices > General Topics - The Lounge
TWControls
I've got a few applications that need a simple relay closure based off of a setpoint on a 4-20mA input. I don't really want a PLC just to read an analog input and turn on a relay.
I hunted through the Phoenix modules, sure that they would have something, but didn't find one.
Does anyone know of a module or a simple way to do this?
OkiePC
How about this?
http://www.actionio.com/support/datasheets...1080_ap1090.pdf
Paul
TWControls
That's exactly what I'm looking for Paul.
Thanks!
TW
Ken Moore
I use the CPA from Moore industries alot. I like the fact that they are configured with a PC, you have lots of options, deadband, high alarm, low alarm etc..... you pick. Plus they also supply loop power for the instruments.
http://www.miinet.com/products/data_sheets/cpa.pdf
ECSI
Weidmuller also have a few different types of process relays:
http://signalconditioning.weidmuller.com/process-alarms.html
TWControls
BudMan
One more source to try.
http://www.api-usa.com/signalconditioners_alarms.php
Bud
imufthi
Does anyone know this component can use for Zone2?
regards,
Ivank
DanW
QUOTE(imufthi @ Apr 8 2009, 01:46 AM) [snapback]80865[/snapback]
Does anyone know this component can use for Zone2?regards, Ivank
If Zone 2 is close to US class 1 Div 2, where nonincendive devices are authorized, there won't be such an animal.
The restrictions for electronics for zone 2 is that they not have any relay contacts which are arcing, sparking devices. Solid state switches can pass, but not electromechanical contacts.
Ken Moore
QUOTE(Ken Moore @ Jul 28 2008, 05:49 AM) [snapback]72006[/snapback]
For the link above, there is an optional ExP field enclosure.
PLCMentor.com
QUOTE(DanW @ Apr 8 2009, 08:27 AM) [snapback]80870[/snapback]
You might want to check the specs on the devices. Zone 2, or C1,D2 would be possible if the device uses hermetically sealed contacts.
Russell
Crossbow
Weidmuller makes a whole line of these type devices, signal converters and relays.
DanW
I stand corrected. Mr. White is certainly correct that hermetically sealed electromechanical relays qualify for US Class 1 Div 2 hazardous areas. I'd forgotten about the pressure switches I've used several times that were so constructed.
Dan
PLCMentor.com
Yeah Dan - problem is that none of the devices listed here have hermetically sealed contacts. I guess even if they did they may opt for not going for the certification. Did a quick search and couldnt find one. So maybe we are both right...Its possible just not available.
Russell
