Full Version: Windows XP Home/ RSLogix
COOP
Will RSLogix 500 V7.0 run on XP Home? I know that the Rockwell compatibility matrix specifies XP Pro, does anyone have any experience with running RSLogix on XP Home?
OZEE
QUOTE(COOP @ Jul 11 2008, 03:30 PM) [snapback]71435[/snapback]
I believe, technically, RSLogix ~may~ run on XP Home -- but RSLinx does not. So, while it may run, you can't do anything with it...
leonuce
QUOTE(OZEE @ Jul 11 2008, 05:19 PM) [snapback]71437[/snapback]
Yes, both run with XP Home. I do have XP Home in my laptop and I haven't had problem running RSLinx, or RSLogic 500.
slcman
I worked with RSlink, RSlogix 500 on windows XP home. I needed to upgrade to xp pro for be able to use RSview ME.
bye
MillerTIME
Question I am trying to install rslinx 2.43 on XP Home but have had no luck with getting it to install completely does anyone have this working with this operating system if so what must one do?
s_dhamayana
Presently i ve used Windows XP Home Edition and installed RSLogix 500 and 5000 in my laptop.
I ve installed RSLINX Rev 2.50 by followed instruction as normally.
And the result, i haven't found any problem.
Could you give more spesified what is the problem you found during the installation such as error messages if any, so we can give more spesified solution for you thumbsupsmileyanim.gif
pandersen
A contractor we hired a while back had no troubles with Logix and Linx on Home, but FactoryTalk will definitely not work, so you can't use RSView.
MillerTIME
QUOTE(s_dhamayana @ Jul 16 2008, 05:28 AM) [snapback]71587[/snapback]
Yes when installing rslinx 2.43 keep getting error unable to install EDS files.
Mickey
QUOTE(MillerTIME @ Jul 16 2008, 05:58 PM) [snapback]71607[/snapback]
Something at link below about that.
http://rockwellautomation.custhelp.com/cgi...amp;p_topview=1
Eluder
You can run RS Logix group RS Linx and RS View 32 with no problems on Windows XP Home, anything with factorytalk requires XP Pro thats all.
