Do you guys know of a PDF manual in the knowledgebase that helps you troubleshoot minor PLC faults?
Here is an example of what I am checking into:
7/8/2008 4:25:29 AM
(Type 06) Program Fault
(Code 04) Unknown fault.
Fault Information Dump:
Info[0]: 00000001
Info[1]: 00000001
Info[2]: 00000000
Info[3]: 00000000
Info[4]: 00000000
Info[5]: 00000000
Info[6]: 00000000
Info[7]: 00000000
I have a really bad habit of using SHORTED rungs to branch around something as an ALWAYS ON, now in RS Logix 5000, that I could not do RS LOGIX 500. So I suspect the Type 6 Program Fault might be that. But the Minor Fault watchdog bit is on, and I am wondering what the Info [0] arrays mean. Any PDFs you guys use for this type of troubleshooting?
