Full Version: Creating a New Routine in RSLogix 5000
themullet
I was just wondering if someone might be able to help. I am trying to create a new Structured Text routine in RSLogix 5000. However when I go to create the new routine, it is only giving me the option to create a Ladder Routine. Does anyone know what the problem is?? Thanks in advance
Bryanr
QUOTE(themullet @ Jun 26 2008, 11:57 AM) [snapback]70776[/snapback]
Your Logix5k License is just the basic one and doesn't include the additional programming languages.
You will have to either upgrade the logix license or purchase one of the addon packs to unlock the languages.
dream_chaser007
QUOTE(themullet @ Jun 26 2008, 05:57 AM) [snapback]70776[/snapback]
Hello,
No, i dont think so. You must look carefully, there will be one option in main programme where you can select the langagues option for programming.
It's first with ladder in main programme may be, but surely, you can change with that option. If you are programming in Add on instruction , you will find very easily while creating new programme.
If you are doing in Main Programme or main routine, you should create new routine and in new routine while configuring you will find this option at last.
Hope you will find it.
regards,
dream chaser
Bryanr
Further Information:
QUOTE
RS Logix 5000 Packages:
9324-RLD300xxE*
RSLogix 5000 Standard Edition
Includes:
* Ladder diagram programming language
* RSLinx Lite communication drivers
* Supports all Logix5000 controllers
9324-RLD300NXxxE
RSLogix 5000 Standard/NetWorx Edition
Includes:
* RSNetWorx for DeviceNet
* RSNetWorx for ControlNet
* RSNetWorx for EtherNet/IP
9324-RLD600xxE*
RSLogix 5000 Full Edition
Includes:
* Ladder diagram, Function Block diagram, Sequential Function Chart and Structured Text programming languages
* PhaseManager
9324-RLD700NXxxE*
RSLogix 5000 Professional Edition
Includes:
* RSLinx OEM
* PhaseManager
* RSLogix Architect
* RSLogix Emulate 5000
* RSLogix 5000 PIDE Autotune
* RSTeststand Lite
If you only have the Standard Edition, all you can use is Ladder. This can be supplemented by the following packages:
9324-RLDFBDENE
RSLogix 5000 FBD Editor Option
(Function Block Diagram Editor)
9324-RLDSFCE
RSLogix 5000 Sequential Function Chart Option
9324-RLDSTXE
RSLogix 5000 Structured Text Option
9324-RLDMLPE
RSLogix 5000 Multi-Language Pack Option (FBD, SFC, ST)
Includes:
* RSLogix 5000 FBD Editor Option
* RSLogix 5000 Sequential Function Chart Option
* RSLogix 5000 Structured Text Option
Replace xx in the catalog number with the appropriate language designation: ZH=Chinese, EN=English, FR=French, DE=German, IT=Italian, JP=Japanese, KO=Korean, PT=Portuguese, and ES=Spanish
Hope this helps you out.
