MarkoSavic
Jun 23 2008, 07:46 AM
I have CX One ver. 3.0 installed on my computer. One month after installation, I lose the "Start PLC-PT Integrated Simulation" button (it goes gray) in both CX Programmer and CX Designer and there for cannot start the simulation. Then I simply repeat the installation of CX Simulator and the button again works normally for another month or so, when I need to do it all over again.
Does anyone have similar experiences?
PdL
Jun 23 2008, 08:25 AM
Automation
Jun 23 2008, 12:30 PM
It is very strange.
I know CX-One Trial. To the 30 days it no longer allows to execute anything.
Alone it can settle again after a "good cleaning".
It proves of upgrading CX-One through the web: CX-One Auto Update
You should be registered. If you are not able to it is that your license has some problem.
MarkoSavic
Jun 24 2008, 08:42 AM
Thanks PdL, it was problem in registry.
I've added missing lines in registry and Simulator works again!
PdL
Jun 24 2008, 08:43 AM
You might want to check if your registry cleaner (if you use one) also checks for invalid application paths. Mine did and since I disabled that check it doesn't happen again.
BITS N BYTES
Jun 24 2008, 04:31 PM
