Full Version: 1769 HSC- which encoder ?
CH+
I am using a compact logix processor with a 1769 HSC card and am unsure which encoders to buy. The application is for a shelf loading carousel system.
Consider a ferris wheel with 50 cars for the first encoder, I will want to re zero the value when each car hits a datum point. The second encoder is on a drive which pushes product into the path of each car prior to the car arriving at the loading area. This is mechanically cammed and a motor drives continually in the same direction while an arm pushes product in and retracts to home in a continuous move.
One further consideration is either drive could be inched slowly in reverse from time to time to escape a jam
I would like to keep it simple and hopefully deal with just a numeric value each time
Thanks
TWControls
You will need an encoder with an A, B, and Z marker.
Of the most popular encoders, one with a Push-Pull or Differential Line Driver will work. I personally prefer the DLD as I have been told they are more noise immune at longer distances.
The 1769-HSC can handle 5-24 VDC.
Do you have a particular encoder brand in mind?
CH+
QUOTE(TWControls @ May 16 2008, 07:10 AM) [snapback]68996[/snapback]
No, anything reasonably priced,what would you recommend. resolution is not an issue and the operation is multi turn, my thought was to use an Incremental, do you agree,
