Full Version: Local ControlNet Node
TurboDurbin
I need to be able to display the node number on the GDU because it will save me from having to change it on different gdu screens and projects. I used a MSG instruction to get the IP information from the ENBT card I just need to get the info from the CNB\E card. This is a 1756-ControlLogix Chassis. I think all I need to do is know the Class, Instance, and Attribute for the CIP Generic Message Type.
Please help me if you could.
Contr_Conn
QUOTE(TurboDurbin @ Apr 28 2008, 11:46 AM) [snapback]68281[/snapback]
See Technote 19053.
Also see TN 24538 in case you need other info from device
TurboDurbin
QUOTE(Contr_Conn @ Apr 28 2008, 06:26 PM) [snapback]68293[/snapback]
See Technote 19053.
I called tech support and they gave me that same TN# 19053 which I found however I can not fins the 24538 that you referenced or the 25592 that they referenced when I was on the phone. Is there something I am doing wrong when searching the knowledgbease?
BobLfoot
I believe your problem is a common one. If your search the knowledgebase for the phrase "old technote" you'll see the difference between Technote ID# and the newer answer ID. The numbers that RA and Contr_Conn gave you appear from my searches of the the knowledgebase to be answer ID. In fact searching by ID and not PREV TN# yileds the following article titles
19053 - Obtaining the 1756-CNBR's ControlNet Station Address.
24538 - CIP Messaging Reference.
Good Luck and try your search using ID and not Prev TN#.
Contr_Conn
24538 is for Techconnect customers only, you should login with your Techconnect Auth# to see it
TurboDurbin
QUOTE(Contr_Conn @ Apr 29 2008, 01:33 PM) [snapback]68334[/snapback]
Thanks for the info finally got to the article. Too bad the .bmp is no good and I can't acctually see the settings I need to use. Oh well I give up.
Ken Roach
For better or for worse, the A-B knowledgebase embedded images don't show on Firefox or Opera, you have to use IE6 or IE7.
If my guess is wrong and you can see the bitmap in Article ID # 19053, what about the CIP Class/Instance/Attribute = F0/1/84 is not of use to you ?
BobLfoot
QUOTE(Ken Roach @ Apr 30 2008, 12:55 PM) [snapback]68368[/snapback]
For better or worse Firefox 3.0 Beta 5 with the IE Tab add-on will show the embedded images. Just tested it myself.
TurboDurbin
QUOTE(TurboDurbin @ Apr 30 2008, 09:22 AM) [snapback]68363[/snapback]
You were correct:
To discover the ControlNet Mac Id use the following message:
Service: 0x0E (Get_Attribute_Single)
Class: 0xF0 (ControlNet Object)
Instance: 0x01
Attribute: 0x84 (MAC_ID)
The data returned by the module will be 4 bytes conforming to the following structure:
MAC_ID_current USINT
MAC_ID_switches USINT
MAC_ID_changed BOOL
Reserved USINT
I didn't know MAC ID was teh same as CNET Node #
