I guess sometimes I am held to the higher standards. See below specifications from Chysler & Ford
Chrysler Do's & Don'ts
4.3.2 Standard Tag For Field Devices
Standard Tag for field devices shall include:
Permanent identification utilizing an approved tag, mechanically attached adjacent to the device.
Each tag shall indicate the device P.L.C. address and Description, function and direction of motion. Characters shall be a minimum 5/32" in height.
Tag shall be readily visible from the service side of the line and must not be mounted on the device it identifies or obscure the manufacturer’s label.
FORD VOSS:
2.4.3.2 All switches shall have a lamicoid tag that includes the PLC description and input address. The tag shall be engraved with text no smaller than 1/8 inch and be mounted adjacent to the switch with drive screws.
2.4.7.13 Tags are to be shown and flagged out for the build supplier on the drawings for each valve, pressure reducer and gage pressure setting. Tags are to be affixed to the machine tooling and read machine function and valve number. All tags shall be attached with drive screws.
