QUOTE(TWControls @ Mar 30 2008, 03:27 PM) [snapback]67068[/snapback]
Most can be optionally mounted outside of a control cabinet, but not outdoors! Though I don't like to do it, I have done this with AB Powerflex and Baldor H2 drives
On top of the humidity and heat, direct sunlight can be a problem with the clear cover over display. It will turn some plastic hazy.
I have installed the AB PowerFlex, as well GE AF300 drives both with enclosures and without...I much prefer doing it in the enclosure, and including the line reactor, control transformer, and control relays all in the same enclosure (depending on the hp of the drive of course). This makes troubleshooting easier, because everything is right there in front of you, and I usually mount a remote HIM on the cabinet door, along with local/remote switch and some indicator lights. I am in a cement plant and dust is ALWAYS and issue, so anytime I can get something in a cabinet I do.
If you want, I can send you a couple of pics of a few of the cabinets I have done with the HIM and indicators on the door...
