QUOTE(Steve Bailey @ Mar 18 2008, 07:40 AM) [snapback]66606[/snapback]
To start a 90-20 running if it has stopped, you need either a hand-held programmer or Logicmaster programming software. It can be configured to try to start running at power-up, but the default configuration is to do the same thing it was doing when power went down. If it was running, it will power-up running. If it was stopped, it will power-up stopped.
That's an old unit. GE Fanuc stopped selling it more than a decade ago. You may want to consider replacing it with something more readily available.
Yes I know that this is a very old unit. We will be replacing shortly with an AB. I was just trying to figure out what might have caused this from happening. The 90-20 should power up in run mode or at least it has been for the past 16 years. Not sure why it would of suddenly stopped unless something went bad inside. Since I don't have the programmer or software I guess we'll never know. Oh well, thanks for your time.
JS
