Full Version: Problem Using data block on NS5
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-Designer
Simon27
Hi there,
I wish to use data block features with NS5 and CJ1M on an application. Everything works fine.
However, i still have a problem :
I have two screens :
- a technician screen where you can add new entries, delete, modify, etc. (with password)
- a production screen with read only capabilities, which is used to select a product and transfer its parameters to a PLC
My problem is that on this second screen, I can still edit the label of the entry, which I want to avoid. If I disable the input on the control flag page, I cannot select nor transfer from the table anymore...
Is there another way to obtain this functionality ?
Thanks for your help.
Andy_P
I have done something similar on a NS8 screen...
Set the 'Record Label' column width to zero, and have an extra text field in your data block that you use to label the record with instead. (This also means that the record name you select can be stored in the PLC, which may or may not be useful to you.)
Next, have a macro running in 'Before Inputting Numeral/String'. I have used this code:
CODE
'Job Name modification prohibited if $B2 equal to 0.
'RETURN(1) means exit macro and abort object operation.
IF ($B2 == 0)
RETURN(1)
ENDIF;
This simply stops editing of any fields and aborts the operation if $B2 is set to zero. ($B2 is nothing special, just a system bit I picked to use.
Setting $B2 to a value other than zero will allow edits to be made to the fields.
Hope that helps.
Andy.
beegee
QUOTE(Simon27 @ Mar 10 2008, 12:06 PM) [snapback]66206[/snapback]
Hi there,
another possibility is to put a transparent button on top of the labels and make it inactive through the control flag ( no macro necessary) I do this all the time
Beegee
Simon27
Thanks a lot for your help. Il have used Andy's solution and it works perfectly.
Simon
QUOTE(beegee @ Mar 13 2008, 04:01 PM) [snapback]66378[/snapback]
Hi there,
Beegee
Andy_P
QUOTE(Simon27 @ Mar 19 2008, 09:46 AM) [snapback]66654[/snapback]
Simon
Glad it worked for you. I must admit though, Data Blocks seem a bit cumbersome to work with.
Andy.
