Full Version: GE IC693MDL330 Output card
Forums.MrPLC.com > PLCs and Supporting Devices > GE
Golfman
Here is my problem..
I have a IC693MDL330 120V output card. We have recently added an output to power a pilot light that will be turned on after logic is satisfied.. The problem is that my pilot light glows dim when the output is in the off state. What can I do to fix this besides using a relay from the output card to turn the light on???
Thanks
Jody
Rod_Hackney
QUOTE(Golfman @ Mar 3 2008, 12:47 PM) [snapback]65909[/snapback]
Thanks
Jody
I am assuming that the IC693MDL330 is a typical AC output card that uses a triac ouput. If this is the case you have two options:
1. Add an interposing relay. 2. Add a burden resistor in parallel with the load sized in resistance to a value capable of bringing down the voltage resulting from the leakage current, but not so low as to create undue heat generation.
milldrone
Thanks
Jody
Jody,
Another option presuming you are using a 120 volt led or neon bulb would be to replace the pilot light whith one that uses a regular fillament type bulb. Preferably one with a stepdown transformer and a #755 bulb.
