Quick question for ya...
I've got two nearly identical machines sitting side by side. Both are running SLC 504's and matching DH+ panelviews. There is a third machine just in between them that is sort of a go between between the machines. (It's running a DH485 on a 503.) Currently none of these machines really "talk" to each other other than via 3-4 digital I/O. There is alot work that could be saved, if they the two outside machines) could pass more information back and forth.
My question is this, would it be posible to throw a DH+ scanner mod into the 503, and tie all these together via the DH+. Then it would just be a matter of changing the node address and updating the PVs correct? (Just to get them running smoothly while hooked to each other... The reprogram for comm between them would come later.)
OR.... Would it be better to just throw 3 eni modules in there and com via the network. (This is most likely going to happen anyway for data collection reasons, but it may be a while...)
