QUOTE(5p6d @ Feb 8 2008, 04:23 PM) [snapback]64915[/snapback]
I have a an output to be turned on with a NO contact input that I'm latching on with the contacts of the output.
Ok, I might be experencing a caffene surplus problem.
Does this mean. I have a NO contact in the field that goes to a PLC input. I need this input to "seal" or "latch" the PLC output on with the logic?
Or does this mean. I have a NO contact in the field and I want to turn on a output and wire this output to the input so it stays on?
There is a NC contact between the NO input and the OP. When the NC contact opens, the output must turn off, however, when the NC contact re-closes, I need the output to come back on....without reclosing the NO switch.
I'm stuck.
Your stuck? I have no Idea what an "OP" is. Is that an Operator Panel?
It might be just the caffene talking but you appear to be using hard wire relay terminology - lingo.
I would like to help but I can't make sense of your question. But it might be just me and my caffene overdose
Edit: I just had another cup of coffee.
Are you saying you have a NO contact in the field that is connected to a PLC input. When this contact closes (momentary) I want a PLC output to turn on, then when it closes (momentary) again I want the PLC output to turn off?
Vaughn
