QUOTE(Atlascycle @ Jan 30 2008, 05:44 AM) [snapback]64426[/snapback]
Be careful about using a round shank tap in the drill chuck, the taps are harder than the drill bits and when they slip it will start to wear out the chuck jaws.
One of the beautiful things about the Greenlee drill taps is that they have a hex drive on them, nice for chucking in a drill or in a magnetic bit holder.
QUOTE(Atlascycle @ Jan 29 2008, 07:50 PM) [snapback]64398[/snapback]
In my experience power tapping with a Drill I have found that you are most likely to break it when you are running it back out of the piece that you are tapping.
QUOTE(IO_Rack @ Jan 30 2008, 05:25 AM) [snapback]64423[/snapback]
... if the bit hangs in the steel it will most certainly break.
When tapping any hole you should reverse the tap every couple of revolutions. This breaks the chip that curls up in the tap flutes. Use a small cordless drill for this, the larger drills have too much power for a job that requires some finess. I actually put them in my Milwaukee cordless screwdriver instead of a drill, it has enough torque to tap up through #12. Be very careful to not put any side load on the tap, keep it straight and hold the drill steady. Side loading is usually what casues them to break. When deep tapping, reverse frequently and every few reverses run the tap all the way out to clear chips.
