Full Version: CX Designer Simulator
Forums.MrPLC.com > PLCs and Supporting Devices > Omron > CX-Designer
dawkinsn
I can simulate a screen with a virtual PLC. Is there a way to simulate a screen with an
actual PLC attached via the serial port?
Thanks!
PdL
QUOTE(dawkinsn @ Jan 28 2008, 10:25 AM) [snapback]64303[/snapback]
Thanks!
Yes you can, from version 2 on. With questions on software capabilities it always helps to mention the version info!
See the CX-Designer users manual which you can access from the start menu programs folder of CX-Designer.
See chapter 4-13-2 "Debugging Screens and the User Program with the Actual PLC".
Hope this helps!
dawkinsn
QUOTE(PdL @ Jan 28 2008, 10:08 AM) [snapback]64305[/snapback]
Thanks!
Hope this helps!
Many thanks, that did the trick!
MIKE31
QUOTE(dawkinsn @ Jan 28 2008, 05:25 AM) [snapback]64303[/snapback]
Thanks!
HI can you tell me how is done thanks
banker
Hi Mike31
In CXProgrammer there is a icon for the simulator. Download the plc program to the simulator. In CX-designer there is a test icon select test to simulator and her you go.
MIKE31
QUOTE(banker @ Nov 6 2008, 09:56 AM) [snapback]75435[/snapback]
Hi Mike31
Thanks for the reply I will try it by the way is there any sample program or manual
