QUOTE(Seatrax @ Jan 18 2008, 01:35 PM) [snapback]63983[/snapback]
I have a micrologix 1500 (processor 1764-28BXB) and I am having problems with one of my outputs that controls a 24vdc horn. This horn is also controlled by a pushbutton in parallel with the output from the plc, causing voltage to be applied to the output pin when the button is pressed. If the plc is not powered up and the button is pressed, the plc turns on for as long as the button is held. What causes this and how can I prevent this other than having to install a diode between the output pin of the plc and the output of the button?
Are you using the FET output for your horn? If so all solid state devices have leakage. Never short a solid state device. ( damage may occur). As finfin said use a slave relay or one of the PLC's relays if available.
