QUOTE(Ron Beaufort @ Jan 16 2008, 01:29 PM) [snapback]63854[/snapback]
from Mickey back in post #3:
QUOTE
Post your code ( .RSP file) and tell us the location of the module.
is there any reason why you can't post the .RSP file? ...
here's what we need to know in order to NAIL this thing ...
(1) the .RSP file ... (this will help us check for memory overlaps - even with indirect addressing problems) ...
(2) the size of each chassis (number of actual slots) ...
(3) how the DIP switches are set on each of your chassis backplanes ...
(4) how the DIP switches are set on the ASB modules of the remote chassis ...
(5) the series (A, B or C) of your analog input modules ...
(6) how the jumpers are set INSIDE the analog input modules ... (differential or single-ended, etc.) ...
(7) how ALL of the modules (analog and discrete) are physically located in the chassis ... (note: use LETTERS A, B, C, etc. to identify the slots - example processor is in slot A, etc.) ... note that with some addressing modes (two-slot, one-slot, half-slot) there are SOME types of discrete modules that won't work when installed next to SOME analog modules ... this might not be an issue in your case, but so far we don't have enough information to say for sure) ...
(8) and maybe one or two other details as we proceed ...
I have tried to attached the RSP file but i get the meassage that i am not alowwed to attacheh file of that extension. How can post the code ? please help
basic idea: once we have ALL of the information, we should be able to say "do this" and it should work - as long as none of the components are defective, of course ... without ALL of the information, all we can do is make suggestions that MIGHT work ... this could take awhile ...
we're trying to help - but all we know about your system is what you're telling us ... so far, that's just not enough to really see what's going on ...
QUOTE
When i tried to attach the code, i get the message that i am not allow to attach file of that extension,
how can i post the code?
