QUOTE(Ken Roach @ Jan 10 2008, 07:11 PM) [snapback]63637[/snapback]
Obviously that's not normal.
If they can make some notes about which LEDs, what color they are flashing, and in what sequence, that might help characterize precisely what is going on inside the controller.
All indications point to a failed controller, though. I've seen LED patterns I don't recognize when an OS update failed, and I've seen them when a DH+ daughtercard failed. Regardless of the reason, the likely solution is replacement of the controller.
Thanks Ken,
It appears that It's repeating the start up sequence over and over.
I suggested cycling power.
verifiy the battery
Do a upload and go online to verify any possible errors, but usually in my experience you will get a FAULT on the CPU if thats the case.
I think they are going to try to wipe the processor (VBB /GRD) and try to re-download.
If that doesnt work then it's more than likely the SLC is faulty.
The processor is quite old, so maybe its time.
I'll post what they find
I'm presently in Maryland tryin to help a California bud
Thanks again Ken
