Texzin
Jan 10 2008, 09:44 AM
Howdy
Any Help would be great.
Ok here is what I am needing to do.
I am wanting to be able to operate this valve that moves a hydralic cylinders.
I will be using a ML1200 with a 1762-If4 and 1762-OF4 mod.
The Valve is a Vickers Proportional #KBFDG4V-3-2CO7N-PE7-H7-10
I don't know where to start . I can program simple analog for amp reading or speed but I don't know where to start with this valve.
Any help with some code would great.
panic mode
Jan 10 2008, 08:20 PM
what do you want it to do?
TWControls
Jan 10 2008, 08:36 PM
What type of signal does the proportional valve require?
ianbuckley
Jan 11 2008, 04:12 PM
It would help if you could post some specifications for the valve and what you are trying to accomplish. I tried checking the Eaton web site, but could only find a German version of the manual for the valve. I don't know near enough German for this to do me any good.
BobLfoot
Jan 11 2008, 07:28 PM
This site
http://hydraulics.eaton.com/products/pdfs/631.pdf talks about your valve with an EATON/Vickers Amplifier. You might find what you are looking for on the EATON site.
