QUOTE(TWControls @ Jan 5 2008, 08:36 AM) [snapback]63402[/snapback]
Need a lot more details to help you out. What type of positioning are you doing? Is it a servo drive, hydraulic servo, air, etc. What type of output card are you going to drive your positioning device with? What type of accuracy are you looking for...
Linear positioning. I'm using a Analogue Output Card (-10 to 10v) that drive an existing Servo Drive.
Actually, there are 2 Axis (If you consider the Rotary action as an axis ), the Rotaty movement is to open a rotary Pump (kind of special fabricated mechanical actuator). Both running using Analogue Voltage. Both using External Encoder. Accuray? I guessed 0.5mm to 1mm for Linear, as for the Rotary valve is the angle of opening.
I have no experience on how to manage Encoder. Linear action will perform Homing ( 2 end point Sensor).
I'm wondering how to treat or calculation especially if the Rollover value because no of revolutions of servo will definately more than one. Can you help?
Thanks
