Full Version: Used PLC needed
sjanko33
Do anybody know where can I buy used PLC in Greater Toronto, preferably SLC500 with warranty. I’m interested only in hardware: modular PLC with at list 1 input and output board and Interface cable.
Thanks a lot,
Dan
Chris Elston
You could try eBay or PLCCenter.com.
sjanko33
Thanks a lot,
Dan
Eddie Willers
You're going to have some trouble finding a "used" controller with a warranty; the warranty is only 1 year and most SLC-500's end up being in use for 7-10 years.
sjanko33
I checked PLCCenter.com but is very expensive. Used-plc.com is much better but still expensive. I am planning to use it for training. Any idea what other AB PLC should I consider?
Thanks,
Dan
Chris Elston
What about just a MicroLogix? I bought one on ebay myself for $89.00 I would not worry about warranty. Unless you hook it up wrong in the last TEN YEARS of automation, I have never seen a DOA AB PLC...let alone worry about warranty...
I use my micrologix 1000 for Halloween F/X displays at my house. This year I had over 450 trick or treaters...it was quite kewl...
panic mode
450???
sjanko33
Chakorules,
thanks a lot for advice. How did you get PLC for $89? Everything what I am seeing is much more expensive. Any advice on bidind? Do you have any idea how much will cost SLC 5/04 with 1 DC Input and Output on eBay?
Thanks again,
Dan
Chris Elston
I got it on eBAY.
http://search.ebay.com/search/search.dll?M...uery=micrologix
I don't know about the cost, but you can look at COMPLETED , FINISHED auctions here:
http://search-completed.ebay.com/search/se...ebayreg&from=R6
Chris Elston
PanicMode.
I started a new thread:
http://forums.mrplc.com/index.php?showtopic=1301
I'll reply there.
I bought 9 SLC5/03's and an assortment of Input and Output modules on eBay for less than $4k. They are being used for training at a company training center.
Good Stuff on eBay if you search....
BRIAN RADWELL
I AM THE PRESIDENT OF WWW.PLCCENTER.COM I MUST CAUTION EVERYONE, ALTHOUGH EBAY IS A GOOD SOURCE, THE PRODUCTS ARE OFTEN QUESTIONABLE. I INVITE YOU TO A SPECIAL 30% DISCOUNT OFF OF THE WWW.PLCCENTER.COM WEB STORE PRICE IF YOU MENTION THIS NOTE. WE STOCK 100'S OF THOUSANDS OF UNITS MADE BY OVER 500 MANUFACTURES. ALL GUARANTEED AND COVERED BY A 1 YEAR WARRANTY. PACKAGED AS NEW WITH FULL TECHNICAL SUPPORT.
MY NAME IS BRIAN RADWELL
GOOD LUCK
Chris Elston
Kind of TV commerical sounding to me...but since the post was about purchasing a PLC with a "warranty", I'll let it slide. thumbs-up.gif
PLC Center is a good source to get PLCs.
You can also try Tek Supply.
http://www.mrplc.com/sites/moreinfo.cgi?140
Check out PLC Center reviews here:
http://www.mrplc.com/sites/moreinfo.cgi?105
Sleepy Wombat
What about my free set of steak knives to go whith the 30% dicounted PLC...
panic mode
Admin alert!
It looks like the messages are mix of different topics. I see Halloween and
cheap PLC together...
Crossbow
My recommendation is Sterling Services in North Carolina. Go to www.sterlingservices.com and get the phone number. I usually deal with a guy there named Jon Frankle. They put a LIFETIME warranty on their USED or REPAIRED products! I get all my older PLC parts or products I'm not a distributor for from them.
If all you're doing is teaching, a SLC500 (not modular) or a MicroLogix should be enough. I personally used SLC503 with 1 input, 1 output, 1 analog input, 1 analog output card. That's my standard PLC for training classes. Have same setups for Modicon, Mitsubishi, Siemens.
bluegoose
yelclap.gif Try www.paragonatlantic.com 5/04 for 756.00 with 1 year warrenty!!!!!!
