I work for DuraLabel and we make the continuous vinyl tape with an orange top (orange header) and white bottom you describe. We also have the preprinted die-cuts for making arc flash labels, including extra large arc flash die cuts, up to 7" x 10.5" in size.
Also, the DuraLabel PRO, PRO 300 and DuraLabel 7000 printers all have Ethernet ports available. Just specify you want Ethernet included at the time you place your order, and it will be included. If you have an existing DuraLabel printer that does not have Ethernet, we've found the small parallel port print servers work well with all DuraLabel printers.
I just checked with our tech support department, and there have been no issues with DuraLabel printers and Ethernet connections. It works fine.
QUOTE(paulengr @ Dec 18 2007, 03:57 PM) [snapback]62996[/snapback]
We've got an old "versaprinter" from them. When I get through the spending on the capital project for updating everything to meet arc flash rules, I'm going to have money left over to buy something not predating 9/11/01.
Where do you get the orange top/white bottom label tape? All Brady sells that I can find is preprinted die cut labels with "Warning" at the top and white bottom. "Duralabel" sells exactly the labels you describe but they aren't really set up to handle multiple users (no Ethernet port on their printers). I'm a little scared by Duralabel because I've had oodles and oodles of fun with Brother printers in the past (unreliable interfacing/software issues). I don't need Ethernet but usually as soon as it implements anything resembling a "real" print server, the goofy nonstandard stuff has to be jettisoned.
