QUOTE(Berti Baker @ Dec 12 2007, 08:26 AM) [snapback]62724[/snapback]
QUOTE(Juan @ Dec 8 2007, 12:37 AM) [snapback]62532[/snapback]
I finally got it
choosing "Ethernet" in the "Network Type" selection.
Yes this is the normal connection method and correct for ETH comms. This mode still uses FINS so not sure what 'FinsGateway mode' means. I know with CLK it is possible to connect to the Network Service Board in the PC. In this case you can choose "FinsGateway" in the network type and specify the FINS node address. However this is not applicable to ETH or useful (unless you have FINS Gateway 2003 Ethernet driver installed too)
My ETH comms are stable - are the timeouts in CX-Programmer or CX-Supervisor? Make sure you check the ETH-01 error log for clues.
Bertie
1.first time ,you have to connectd plc by serial cable.
2.goto io table and creat it for plc can see any module
3.in io table go to etn module and click setup
4.at IP address you set 192.168.1. ... ( up to no.of module)
5.subnet set 255.255.255.0
6.select tap tranfer to pc if anything ok software ask for starting module click ok
7.at module you will see lamp run lid , don't show lamp red
8.in io table you need to setup routing network
9.you can see tool menu starting routing and setting click !
10.softwear will show window for set routing network , you select no.1 and double click , and select insert siou
11.window will show module no.1 and link line with network#1
12.select tap tranfer it to plc , now any think ok lamp run ,100m,link is lid
13.at cx-programmer select connection ethernet and click setting
14. at network goto fin destination and set network(=1) and node(=up your setting module)
15. select tap driver set IP address 192.168.1... ( 2 set last no.up to your setting module)
16 finish your setting in cx-programer test it
note
1. IP adress on pc not the same plc example in plc 192.168.1.10 in pc need to 192.168.1.8 ,,, subnet is the same 255.255.255.0
2. cable rj45 you need to used cross type
