QUOTE(beegee @ Nov 13 2007, 04:33 AM) [snapback]61589[/snapback]
Hi Chako,
Nice....
how about the performance and stability? I have a SUSE 10.2 X64 with Vitual Box installed but I still have to install a Windows version onto it. (is still on my todo list)
I have a few questions before I start installing XP or 2000 on it.
Did you need to have a disk formatted in NTFS or is this also being emulated by Virtualbox?
Can you access your serial ports (for programming purposes)?
beegee
It's very stable. No crashes yet in either host or guest.. I've been loading in software and no problems yet.
I was not able to get RS LINX to work, even though the serial port "seems" to be there. So at this point, no go there. I don't have an USB programming cables, so I can't test the usb support. The USB is working.
I insert my flash drive into the box, and Linux picks it up, and Windows picks it up at the same time. What's freaky is when I copy a file from Linux on to my flash drive, it instantlly appears in the Windows guest. I bet the Windows Box if it had a mind, would freak out...speaking of which in that same frame of mind, if the Windows box had a mind, it would be considered a "matrix"....it's well emulated for sure...
I guess why I am impressed is because Virtual Box is free compared to VMware, like everyone likes to use. I like it when free stuff works well.
When I installed Windows 2000, it was like booting a new PC, I booted from a cd-rom, and it installed. When it came time to format the drive during setup, I choose NTFS. I did not "physically" create a partition on my "real" hard drive. All you do is allocated how much space in Virtual Box, I allocated 20 GB. So "virtually" it formated a hard drive of 20 GB, to NTFS, but my orginal hard drive still is ext2 partition.
