mmicomp
Nov 8 2007, 08:02 AM
Hello
The atached PLC 5/05 Program faults on a ASCII String Manipulation error when run through the RSLogix 500 EMU.
ASCII String Manipulation S:5/15
This bit is set (1) when an attempt is made to process a string using an ASCII instruction that exceeds 82 characters in length.
Any help in locating the offending String/ASCII instruction would be greatly appreciated.
Peter
mmicomp
Nov 8 2007, 10:41 PM
Hi
For what it's worth, the Fault condition in the above program file attached (above) cannot be cleared ?
Peter
mmicomp
Nov 9 2007, 09:12 AM
Figured it out to be the indirect pointer C5:3 that is used in some ASCII instructions.
When I set the .acc to 1, I am able to clear the fault.
Still have to figure out which rung 7:46-51
Weird that the Major Error locator does not indicate the offending rung.
Found some stuff in the instruction set manual that discusses the error bit S:5/15, but not really much help.
I think I am on the right track anyway, thanks to all who viewed the posting.
Peter
Chris Elston
Nov 9 2007, 11:06 AM
so I got one question...
I looked at your posted file and I see that your looking at a program with no descriptions, and no symbols...is that how you de-bug the program now? if you are...you're more of a man than me.
That maybe why your not getting much help, what I am trying to say it's diffcult to troubleshoot a program like this without some indication with descriptions what the orginal programmer was thinking.
Kiwi Sparky
Nov 11 2007, 05:07 PM
Try Looking at ladder 11
The N220 words that are being moved to strings may be causing problems?
click here.
