Full Version: micrologix 1100
wilmar
hi friend i new in plc ab, please cold you help me ?
i have the rs logix500 version 7 and rslinx 2.50 but when i made autoconfigure no reconize the plc.
the serie of micrologix 1100 is serie A .
cold you tell me some ideas ?
thank a lot
regards
TWControls
Are you trying to connect over Etherent or Serial. Since you use the term autoconfigure I'll guess serial. What cable are you using? Do you have a real serial port or a USB to serial adapter? Are you currently able to connect to other AB PLCs?
wilmar
QUOTE(wilmar @ Oct 31 2007, 10:25 PM) [snapback]61087[/snapback]
cold you tell me is the version about software is correct?
thank a lot
regards
Mickey
QUOTE(wilmar @ Nov 1 2007, 08:51 PM) [snapback]61128[/snapback]
thank a lot
regards
Yes
Mickey
QUOTE
thank alot friend i going to check .the plc because when i made autoconfigure no reconize the plc in DF1 only appear estacion 00(pc) my cable es new and the plc is new.
thak a lot mister Mickey
regards
wilmar
See PDF
Also see link for instructions on how to connect to your serial port. ( the link is for a ML1500 but it will also work for your ML1100)
http://www.mrplc.com/kb/index.php?page=ind...;id=65&c=11
