I have a material handling application controlled by multiple ControlLogix Processors. Data regarding product details for each possible position in the system is stored in a LARGE array of tags based on a UDT that is quite complex. My RSView SE application has a screen that displays the location of each product container in the system that can be clicked for details about that particular containers product. This information is read from element(x) of the MyBigUDT Array. Now the customer wants to see color coding of the containers from the main display screen based on product codes. So my problem is this;
1. I can go to each screen element and write an expression in the Animation->Color dialog to change the color based on the product id (which is a subelement of the MyBigUDT Array), however this will require writing almost 1000 unique expressions for each of the container objects, which I obviously don't want to do.
2. I can write VBA Code to change the color of each container object, however since the container objects in RSView cannot be an Array of objects and VBA will not allow you to build Object, Variant or String Variable Names by combining text and string converted numbers, then my only option is to write almost 1000 unique lines of code to change the color of each container object.
So my question to the guru's is this;
Is there a work-around for the RSView Limitation of creating arrays of screen element(such as polygons, numeric data displays etc.) Such as some other method of indexing through multiple identical elements on the screen? And, is there a way I can directly read/write PLC Tags from VBA without a separate DDE/OPC link? If this were a single DINT, or REAL or BOOL I could create a reference tag in RSView, but you can't create an Array of Reference Tags in RSView, so again, I would have to create nearly 1000 tags in RSView with each one pointing to a different element of MyBigUDT.
Obviously the object here is to create a For Next Loop in VBA that will do a lookup on the correct array element, and ideally to be able to use the VBA event for Numeric Data Display Change() to update the associated Polygon (I have a grouping of a Polygon and a Numeric Data Display Field) With Polygon1 and NDD1 through 999.
Any suggestions or workarounds would be appreciated. Surely others have run into this wall, I'm at the point where I think I need to write a standalone VB application that I call from RSView to save on coding.
Regards
E
