Full Version: Link from Computer to 1747-L511 Processor
Steve Cheung
Dear All,
Anybody experience in communicate / link between computer and the SLC5/01 CPU 1747-L511?
I have install the RSLOGIX and the RSLINK, but don't know what is driver name use for such cpu.
Should I set the device and station no? When I press auto configure, the result is error.
I need to upload the ladder from the cpu, but seem computer & cpu cannot communicate.
Thanks & best regards,
Steve
arj3090
What are you using for the physical connection, PIC module or 1747-UIC?
Steve Cheung
QUOTE(arj3090 @ Oct 26 2007, 09:58 AM) [snapback]60933[/snapback]
Hi....
Yes, I am usin the 1747PIC interface.
Can you help?
I attach the print screen, pls advice if something wrong.
Best regards,
steve[attachmentid=5517]
Mickey
QUOTE(Steve Cheung @ Oct 29 2007, 01:42 AM) [snapback]60976[/snapback]
Hi....
Can you help?
Best regards,
If you have the 1747-PIC then you need the 1747-PIC/AIC+ driver in RsLinx ( see PDF's below)
You will have to have a real serial port to use this driver.
slcman
Mickey made a good job, but I just want to remind you if you didn't see plc in RSlink (rswho browser) maybe the baud rate if 9600. By default PIC driver install a 19200 baud rate comm.
If you didn't have a native serial port, I can sugest to you a PCMCIA or ExpressCard with a serial port. It's work well. http://www.quatech.com/products/mobile_connectivity.php if you want to see it!
TIP TO ALL -> 1747-UIC don't work at 9600 baud! I had this problem with a SLC fix unit with a HMI connected at 9600 baud. I had to use my old (and big) PIC module.
Good luck!
Mickey
QUOTE(slcman @ Oct 30 2007, 05:38 AM) [snapback]61027[/snapback]
Good luck!
And per Rockwell the 1747-PIC/AIC+ driver will not work with a PCMCIA card. Have you done this?
slcman
I'll test it this week and post the result.
slcman
I can't install PIC driver with PCMCIA serial port. I'm surprise! It's the first time it doesn't work. It's work with omron, siemens, directlogic, TI-soft (texas instrument in DOS), Mitsubishi, ....
maybe a patch exist....but I don't need it, I use 1747-UIC for DH-485
Mickey
QUOTE(slcman @ Nov 6 2007, 08:23 PM) [snapback]61300[/snapback]
Thanks for the update.
Steve Cheung
QUOTE(Mickey @ Nov 6 2007, 09:19 PM) [snapback]61301[/snapback]
Hi Friends....
Thank you for every information from you all. I have follow all your instructions.
I have test with the notebook with USB port, but it cannot communicate with the PLC.
But, I have try to find a pc with serial port, and test last week. It work's well.
Thank you all for your great job!
Best regards,
Steve
