QUOTE(PdL @ Jan 21 2008, 04:13 PM) [snapback]64081[/snapback]
QUOTE(PLC4me @ Jan 21 2008, 08:22 PM) [snapback]64077[/snapback]
That is what I am trying to figure out. but just how do you select a task button? do you use the Tasl-List ans set the info under Global Task? I don't see any acknowledge selection in the dropdown menu. you would not have an example file would you? I realy would like to get this project moving forward.
thank you
You are almost there, it is just not that obvious.
For a bit button, you can add a task at the most right tab. It can be data manipulation e.g. setting a bit or resetting a bit, but also other tasks.
As one of these other tasks you can select "key specific task", I believe it is the most bottom one in the dropdown menu. Then you get all kinds of functions you can select for the task, two of them are "acknowledge single alarm" and "acknowledge all alarms" or something like that.
I don't have the software here right now, I can post an example tomorrow if you wish.
Thanks, That really help me, I found the menu you are talking about, the only think I can't select the all alarms option it's grey out. So I set more then one task for the same function key one for clear alarm one for clear last alarm and one for previous alarm, it seem to work for now I will keep playing with it ans see if this will be the solution that will be best for me.
One again thank you for your help, I can see me coming a big fans of this forum. great respond time and the right answer the first time. JUST PERFECT!!
