QUOTE(cdobis @ Sep 17 2007, 09:59 AM) [snapback]59287[/snapback]
QUOTE(maurice402 @ Sep 17 2007, 10:46 AM) [snapback]59285[/snapback]
hi everyone i'm maurice,i'm new here.
i work in a Clay Block making plant in Trinidad & Tobago.
i'm working on a FoxBoro Panel to control the Kiln and it use the AD 1794 modules and i have alot of problems with them, like bad readings and signals. any addvice?
Hi Maurice,
Tell us more about your setup. Are you setting temperatures, reading temperatures, turning relays on and off, what modules are you using, and are you using DeviceNet for communications, etc?
Craig
it has 2 FoxBoro Micro-IA units, each have 3 racks with AB 1794-ASB's on it, then its got 1794-IT8 for temperature (TC), 1794-OW8 Relay output, 1794-OE4 Analog output, 1794-IA8 120VAC input, 1794-IE8 Analog input, 1794-PS! 24VDC output, all will mgo back to the Micro-IA units then to the computer(running Windows NT v4.0 sp3) via network card. right now my main problem is some of the temperature readings are not accurate, the TC's are about 60' to 100' feet away.
